How Do I Enter Into The Boot Mode
How do I enter into the boot mode of the Lenovo Ideapad laptop? I am pressing all the required keys that are generally used on all PCs to enter into boot mode.
In most of the PCs and laptops we have to press the following combinations in order to get into the boot mode:-
Shift + F12
Escape + F12
F10 + F12
Shift + F2
In earlier Lenovo Laptops, one of these combinations was actually valid in order to provide boot options or the BIOS mode before loading the Operating System.
However, when you try these combinations on new Lenovo Laptops such as Ideapad 320, they don’t work.
Hence follow the steps below, in order to get into boot mode of your Lenovo Ideapad.
On the left edge of the keypad, you have slots for USB and SD cards. You also have LED indicators. Adjacent to the power LED indicator, you have a tiny hole. There is a small button in that hole and you need to push that button with a safety pin. As you will push this button, the Laptop will get on and automatically get into boot mode.
