hugh egnor
20 points
Posted on - 01/31/2013
How do I export to excel JavaScript image ? I need a method to export the images to the Excel sheet. I should be able to click on the image that can link to show the image in the spreadsheet. Please suggest me a way to do that.
I am sending the full code to export the data to the Excel file but it is at vb.net (asp.net).Here Data Grid is used, you can call image instead of data. In the datagrid it will be exported to the Excel sheet. The concept is quite simple whenever the Word or Excel file is transmitted to the client.
Hope to enjoy it and be able to export an image to Excel and Word.
Code: See attachment
Thanking you
Franking Mary.
