pat dawson
40 points
Posted on - 10/24/2012
Is it possible to export VMware Images to an ISO image? I know it's possible to do ISO to VM but is it also possible to do VMware to ISO? Is there a specific program or software to do that or can I do it manually?
How do I export vmware images to ISO?
No, you cannot export VMWare Images to an ISO file. Actually you don't need to do that. If you just write the image file from your disk to CD/DVD and run that from your VMWare.
There are many software’s available for this purpose like Easy CD Creator or WinISO. You can use them for ISO file creation. These applications will allow you to save the VMware OS image as ISO file. There is an option in the VMware machine to export the image you can also try that. I hope this will helps you.
Thank you.
ISO usually refers to the CD image. What you want is not actually the way. Turn Key installation can help you to solve your problem. But if you want to convert ISO to VM then i think it is not actually possible. That is what i am trying to say.
Thank you.
