How do I find more online shopping stores?
1- Use Google to search for the product you want
2- You can use Google trends to know what the latest products that people bought and what stores they bought from.
3- You can go to yahoo directory and go to shopping section you will find more and more
Hi Mokai,
You can use the links below to find the online stores
https://www.finder.com/online-shopping
https://www.lifewire.com/shopping-sites-online-3482901
Hope this helps 🙂
Hello Mokai,
The first option is searching through Google. Enter the name of product you are interested in purchasing in the search engine. On the left side of the page under "search" you will see a number of different options you can select from, to filter your google search. What you are looking for is located under the category of "shopping". Â When you click on "shopping" you will be taken to a page that will display the different brands of that particular product you are looking for, as well as the stores which provide the most competitive prices for that product.
You can also use the website "Nextag" which offers a variety of products from different places and allows you to compare prices.
