Juan Miguel
Posted on - 08/05/2016
Hi. I have recently signed up for Netflix. I would like to know the steps to be followed as to how do I find Netflix on my TV. Since I have a subscription for a limited amount of time, I need to know it ASAP. Please reply as and when you get time. Thanks in advance.
S.SAJMIN
15 points
How Do I Find Netflix On My TV Without Taking Much Time
Hi. The steps as to how do I find Netflix on my TVare as follows-
1. Look for the output ports on the laptop
2. Then, connect the laptop’s port which is its output to the input port of the TV
3. Then, connect the headphone jack of the laptop to the audio input of the television
4. Switch off the TV and then select the correct input to which the laptop is connected
5. On your Windows, press the Window key and P together and then click on duplicate
6. The screen of the desktop will appear on the TV
7. However, if no screen is visible then ensure that the correct output has been selected
8. Manage the sound on the laptop by right-clicking on the speaker option and then clicking on playback devices. There will be a list of devices available from which you need to select your device and set it as the default device
9. Then, open the website of Netflix on the browser and log in
10. Click on the video which you want to watch and enjoy Or
1) Find out if you have a Smart TV
2) Connect the smart TV to the home network with the help of wireless connection or an Ethernet cable
3) Then, open the list of all the smart TV apps
4) Click on the Netflix app
5) Sign in to your Netflix account using your credentials
6) Use your remote to help you go through the website and watch videos of your choice
Hope we helped.
