How do I find a .prn to Excel converter online?
I want to be able to view all the .prn files created in an Excel format. Where can I find the extension .prn to Excel converter online?
Best Answer by Dyer Pearlman
Answered By 0 points N/A #195004
Hello Dear,
Thanks that you have shared your problem with us.
I hope i will satisfy you.
Dear if you want to just read you prn file, so kindly visit this website.
http://www.viewdocsonline.com
It will open a page having a browse button on it. Simply press this button and choose your file. It will open your file online.
And
If you want to convert your file prn to excel, then kindly download converter from here.
http://ptf.com/download/fast_prn_to_excel_converter_demo/6698950/
I hope it will help you.
Regards
Answered By 0 points N/A #145947
Hi Christina Roy,
If you want to convert .prn formats to Excel, you can use a software that is available online. It is known as Fast PRN to Excel converter. It allows you to convert to CSV and TXT formats too.
The following are the features of Fast PRN to Excel converter:
1. Ability to support batch conversion using sub folders
2. Supports the dragging of files and folders on the desktop
3. Has the ability to convert so many files at once taking less time
4. Ability to incorporate file filters
You can get this on the link below
http://www.softpedia.com/get/Office-tools/Other-Office-Tools/Fast-PRN-to-Excel-Converter.shtml
