K Scatter
110 points
Posted on - 08/05/2016
Hi. I am having this doubt from quite some time now as to how do I find spell check on my computer. What steps need to be followed to turn on the spell check on the computer so that grammatical errors and spelling mistakes can be avoided? Please reply ASAP. Thanks in advance.
How Do I Find Spell Check On My Computerin An Easy Way
The steps to know as to how do I find spell check on my computerare as follows-
1) First install the proofing tools
• Close all the programs
• Click on start and then select the control panel
• Under programs click on uninstall a program option in Windows 7
• Click on change and then select the MS Office edition
• Click on add or remove features in the MS Office edition and then click on continue
• Then under Office shared features, then click on proofing tools and then select the option run all from my computer
2) Then as you type enable check spelling
• Click on file menu and then click on options
• Click on proofing in the word options dialog box
• In the correcting spelling and grammar in word, ensure that you select the check spelling as you type option
• Ensure that all the entries are cleared in the exception for tab
• Click on OK
3) Select the language and uncheck the option of do not check spelling or grammar
• Select the content of the entire document
• In the review option, click on language and then click on set proofing language
• A language dialog box will appear in which you need to select the language you want
• In case the “do not check spelling or grammar” box is selected, uncheck it to ensure that the spelling is checked
• Click on OK
Hope we helped.
