How do I fix corrupt ACL file?
Hi guys.  I need your help.  My desktop keeps on freezing and hanging.
I'm having an error of "C:WindowsSystem32 ACL failed error code".
How do I fix the corrupt ACL file?
I'm on Windows 7 64 bit.
Any help would be much appreciated.
Thanks in advance.
Answered By 0 points N/A #141052
Hello Doriswneil,
Startup Repair usually starts on the X: drive when it's repairing – and there's the C:drive, that's the boot partition – then Windows resides on the D: drive/partition.
Try the instructions from this link:
You can try to run SubInACL through the Command Prompt in Startup Repair.
You have to open up the Startup Repair and select the Command Prompt option
Foster Mutchler
