I will get straight to the point. I really need a lot of help from somebody who knows how to stop this error message ‘‘Internal Data Corrupted’’ from appearing. It has already wasted my time. I don’t know but every time I open the Virtual DJ software this error would then appear.
Does it have something to do with the program I use in my PC? I have Windows XP Service and I am just wondering if it has something to do with the error. I need to know what to do because it really takes much of my time. Is there any other way that I can do so that my song list and cue points would not be lost every time this error strikes?
How do I fix the corrupted Internal Database of my Virtual DJ?
Please follow These Steps:
1. Go to program files/virtualdj.
2. Open Virtual DJ database.xml in text editor.
3. You see Songs Like This:
<Song FileName="DJ N'Erick feat. DJ Style – Satisfaction.mp3" FileSize="5572230" TagDate="511180255">
<Infos SongLength="15357312" Date="511180254" />
<BPM Bpm="18634" Phase="5077" />
<FAME IsScanned="1" Flag="7" Volume="6108" />
<Automix MixType="3" TempoStart="1346732" TempoEnd="13868780" CutStart="154176" CutEnd="14605024"
FadeStart="26112" FadeEnd="14776320" />
</Song>
4. Look for any Songs which do not have the </song> tag if found any that type of songs which does not have </song> please ADD this tag after it.
Source: http://es.virtualdj.com/forums/82552/PC_Version_Technical_Support/Internal_database_corrupted.html
Hi.
There are two ways how to fix corrupted internal database in Virtual DJ.
1) You have to navigate to Config → Browser.
From there you shall choose all drives with music stored and check the Fix option.
By clicking on Clean you can remove old database from songs that are no longer exiting.
2) Navigate to C:Program FilesVirtualDJ and search for the file database.xml.
Open the database in any text editor ( Notepad or Microsoft Wordpad ) and search for songs without </song> tag and ad it.
Queen Norman
