I recently encountered a problem with my Google Chrome browser. Itt directs me to a page where it's full of codes and words of the website. I tried to reload the page and it went back to normal. When I clicked another link, it directed me again to a page with codes and stuffs. What can I do?
Please help.
Marco123
Google Chrome Redirected me to a page full of codes
Hello there!
I think you are experiencing redirecting the browser from one URL to another. Some reasons of web applications issue of directs is to indicate the new location of a source that moves or connects different parts of a site or application of different protocols, different securities tec.
It is important to minimize the number of redirects issued in your application. The best way to do this is to restrict your use of redirects. Never reference URLs in your pages that are known to redirect to the other URL. Minimize the number of extra domains. For less hassle, you just reinstall the browser to have the original settings on it.
inirmal
This may be due to unauthorized plug in/extension in the browser you are using. Try pressing ctrl+shift+N, and try using incognito window. In incognito mode, plug-ins and extensions are disabled. If the problems persist, try ctrl+shift+delete, and clear cookies. If incognito mode renders the page well, the problem is with your plug in. Type about:plugins and disable untrusted plug-ins. Hope this helps.
