How Do I Fix The Windowsupdate_8024200D
I’ve been trying to install SP1 for my Windows 8 PC, but couldn’t do so because of the windowsupdate_8024200D error. I’ve tried restarting and installing the update, but no use. How do I solve this error?
Answered By 20 points N/A #321179
Did you change anything in your PC after or before the error? If yes, then please restore it to its original form.
• First, try disabling the anti-virus temporarily and then try to install this update.
• Or else, try installing the update after clean boot while disabling the antivirus.
After clean booting, follow the steps given in this website to bring back its usual start-up.
• Also, try doing these steps while allowing the windows firewall to give the public access to the windows update.
• Or else, try doing an SFC scan by using the SYSTEM FILE CHECKER tool to troubleshoot the missing and corrupted system files.
• Or else, run the system update readiness tool.
