How do I form clickable calendar php
How do I form a clickable calendar PHP where users can click events added by another user?Â
I'm hoping that the calendar could also be exported iCal.Â
Do I need MySQL for this?
After researching I found Eventer that is PHP jQuery Interactive Events Calendar.
You can download from this website: It have light and dark color options, interactive interface, unlimited events, repeat events and many more things.
Also,you will get the source code for Eventer. I don’t know is this what you are looking for but you look at, maybe you will get some idea.
Also,you may look at this link: there is PHP Event Calendar, if you order you will get free installation, MySQL database, customizing calendar to match your website design and many more things.
Williamson Mellisa
