How do I format sticky notes in Windows 7
I am trying to change the default format in sticky notes on windows 7.
Can you change the format and if so how ?
Dear User,
The original settings in Sticky Notes, unfortunately, are to not change the default settings.
You can change information per sticky note with preset keyboard commands.
Below is a cheat sheet of commands for Sticky Note.
Keyboard Command |
Function |
Ctrl+B |
Bold text |
Ctrl+I |
Italic text |
Ctrl+T |
Strike through |
Ctrl+U |
Underlined text |
Ctrl+Shift+L |
Bulleted (press once) or Numbered (press twice) list |
Ctrl+Shift+> |
Increased text size |
Ctrl+Shift+< |
Decreased text size |
Ctrl+A |
Select all |
Ctrl+Shift+A |
Toggles all caps |
Ctrl+L |
Left aligns text |
Ctrl+R |
Right aligns text |
Ctrl+E |
Centers text |
Ctrl+Shift+L |
Small Alpha list (3rd), Capital Alpha list (4th), small roman (5th), Capital roman (6th) |
Ctrl+Scroll Wheel |
Increase/Decrease text size |
Ctrl+1 |
Single-space lines |
Ctrl+2 |
Double-space lines |
Ctrl+5 |
Set 1.5-line spacing |
Ctrl+= |
Subscript |
Ctrl+Shift++ |
Superscript |
Ctrl+Z |
Undo |
Ctrl+Y |
Redo |
Ctrl+X |
Cut |
Ctrl+C |
Copy |
Ctrl+V |
Paste |
Ctrl+N |
New sticky note |
These are you basic commands for Sticky Notes.
If you have to reset a default for your program there is a way to do it with a resource intruders.
Here is a link to that tutorial.
Thank You!
Hello Arthur,
To change the default font format of the sticky notes, all you have to do is cut and paste the text into another word editor for instance ms word or word pad and then change to the font you want while there.
When you cut and paste the text back to the sticky note it will take the font it was in while in ms word or the word pad.
If you need to:
Hope this helps.
Carl
