How Do I Get An Internet Connection?
Internet facility has become quite easy as the need increases day after day. There are two methods that you can go for:
• Indirect connection; It is used for larger areas like home and offices. It is fabulous as it works fast and is reliable. But you can not take them outside anywhere with you as it has a fixed connection. You can also share it with your friends as it has unlimited data. It is set up with your telephone wiring. For this, you can call an internet service provider and ask for the internet subscription. Then you will be provided with a wireless router and a modem. Connect your router with a modem. Switch on the router. At the back of the router, the Id address and password are provided. Connect your mobile with the internet.
• Direct connection; It is directly connected with the mobile by using the 3G/4G network. It can be used anywhere anytime. You can use it while traveling at work, at home. You just need to recharge your internet package. You can not share the connection with any other person as there is a data limit.
Notifications
