How do I get an Android swf thumbnail view?
Hi.  I have the 32 GB LG Optimus Pad LTE that has a Qualcomm chipset, Dual-core 1.5 GHz CPU and Android OS Honeycomb.  I have a couple of swf Flash video files that I want to view on my desktop.  I plug my LG to my PC and go to DCIM folder.  All I see is a photo icon viewer.  How do I get an Android swf thumbnail view?  My desktop is on Windows 7.
Answered By 0 points N/A #148549
Hi Elija Hale Jandroo
Since you want to view your SWF Flash Video files on your PC, it would be best for you to download iWisoft Flash SWF Converter that will enable you to convert Flash/SWF files into lots of formats. This software will help you convert your video files into many video, audio and image files in a very easy way. Moreover you can extract images from your video files and extract audio from any part of your favorite video file.
