How Do I Get Internet On My Laptop
Hi. I would like to know the steps as to how do I get internet on my laptop. What are the steps to be followed? Please reply ASAP. Thanks in advance.
The steps to follow so as to how do I get internet on my laptopare-
1) Set up the wireless router first
2) You can also use a USB modem, follow the steps given below-
• Select the start menu
• Right-click on the computer option
• Then select the properties option
• Click on device manager
• In the options mentioned in the control panel options, check if the Wi-Fi adaptor has been listed
3) Then select the wireless network from the Wi-Fi networks available
4) Click on the name of the network. Enter the password and get connected to it.
5) When you will be asked to choose a home, work or public network then connect to the network.
Hope we helped.
Notifications
