How do I get my files on my external harddrive to work?
I transferred files to my external hard drive from my laptop. Then when I tried transferring the files from my external hard drive to my desktop some files did not want to open. I already deleted the original copy from the laptop.
How do I get those files in my external hard drive to open?
Best Answer by Iamexpert
Answered By 0 points N/A #159147
Yes dear, you are doing the correct thing I have gone through your problem and got that you are doing the same thing the only problem is that you have problem in your laptop or your hard drive do something for these things or put them on hard to solve this problem. This problem will resolve only when you will get through this solution and you will find out how to solve this problem in very short time and in less moment.
Hope you will like the answer or do something for me. I will do that. Hope to hear from you very soon.
Thanks
Answered By 50 points N/A #159148
It seems your data got corrupted so could not open in desktop. But if you want to recover your original data from the laptop then you can try run a recovery software (available for both Win & Mac). The recovery software will recover your original data for access.
Before you buy I would suggest you to try a free demo version of recovery software from Stellar Phoenix.
