How do I get raster3d and/or povray working with WinCoot
Hello Marci,
All you need to do to be able to get raster3d and/or povray working with WinCoot is to download and install the appropriate program raster3d and wincoot should be able to find them. It would be much better though if you put them in to your PATH.
Please rely on the link below for the appropriate program which you need to download and install:
http://skuld.bmsc.washington.edu/raster3d/raster3d.html
I hope it helps. Don't hesitate to ask more questions if you don;t understand something. It would be my pleasure helping you. Thanks and have a great day.
Zorian
Hi Marcy,
Well this is not a big problem to resolve.
Best Regards,
Aabel
