Hello
What is the best remote access/control program (that works with vista) so I can connect to my computer at home through my computer that I am using at college.
I am also going through the school's network so that means I am going through a router as well.
I have downloaded Radmin which works well on vista.
How do I get remote access to a computer over the internet?
Thank you
You can try the TeamViewer for accessing another computer remotely. Just click on the link below:
https://www.teamviewer.com/en/?cdsplit=C
It supports Windows Vista and Windows 7 and allows you to access your computer or another computer for a remote assistance, impulsive support, accessing computer while you are away, and more. Most of all, it provides an extremely secured connection with a complete encrypted data channels that utilizes 1024-bit RSA key exchange and a 256-bit AES session encoding. It also has the feature of drag and drop while performing file transfer. It is just like you are working in front of your computer. You can also use this program on your Smartphone.
First I would like to thank Garry Liberty for asking this question because the idea of remote accessing my computer has never ever occurred to me before and I find it a very cool idea. And Ii would like to thank Fishcharinta Cra for recommending TeamViewer. I will definitely try it! And finally thanks to ever so helpful techyv.com
If you need to access your computer at home from your school, I guess the best option is to use TeamViewer. It is an application designed for internet-based remote access and support. It allows you to connect to any computer or server that is connected to the internet to control your friend’s computer remotely as if you are sitting right next to it.
To establish a remote session between your computer and your friend’s computer, your friend’s computer should also run TeamViewer. To access your friend’s computer, you need to log in to your TeamViewer account. If you don’t have an account yet, you need to create one. Once you are logged in, you will see a list of computers associated with your account.
If your friend’s computer is listed, just double-click it to begin the remote session. But if it is not listed, you need to enter your friend’s TeamViewer account and password to begin the session. For a complete guide, visit How to Log In Remotely with TeamViewer. To get the latest version, visit TeamViewer for Business and Personal or TeamViewer for Windows.
