How do I get a VPN server account?
I have needed a VPN account. I want to use this server with some PC. Have you any idea about this server? How do I buy a VPN server account?
Advanced Thanks for reply.
Judy Plum
Judy Plum
Hello!
There are various preferences for having a VPN account, either on paid or free version. Having a free VPN account is essential to make this work but it's a bit complicated to create one. But it is because of some comparative adversity when making a VPN account. To create a free VPN account, please read on the instructions below:
1. Go to https://www.cyberghostvpn.com/en_US/.
2. Click on Purchase link and then select Free and click Download.
3. Just simply follow the instructions on how to install. Go to The Setup Wizard of CyberGhost VPN and relay with Step 5.
4. Register a new account.
5. After successful registration, login using your username and password.
Congratulations, you've got a free VPN account.
Hello Judy,
I have read your question. I found by analyzing your profile that you are Australian by resident. You can buy VPN account in AU by contacting proper authority. But to buy VPN account online there are many scopes available for you. I have found many companies waiting for you to come forward. Here is a list-
These are widely used among lists of the vpn provider. Among them I would prefer the second one to choose as this is the mostly used vpn service provider in AU. Hope this will help.
Thanks
