How do I get Windows Aero on Mac?
I have a MacBook Pro that has the 2.6 GHz Intel Core i5, 8 GB RAM, Intel HD Graphics 4000 and OSx Snow Leopard. Is there a way to get Windows Aero on Mac? I'd really would like to have this on my Mac. Thanks.
Greetings! There are many web sites that can help you with this, simply google them. If you are looking for that Aero transparency look, sadly, there is none any that I can find on the Internet that can be used in Mac since both of them differ in configuration. But there is the Aero Snap, it can be installed to your Mac where you can just google the software in the internet. You can also use third party software that can give that transparency feel in Mac that is similar to Windows Aero.
