How do I import contacts from new pc studio instantly?
I want my data to be imported to contacts from new pc studio to my phone. How do I import contacts from new pc studio instantly as soon as they connect?
If you want data to be imported from your PC studio to your phone, first you need a software that is supported on your PC. Then, your will need a cable for your phone to connect it to your phone. You will then be able to transfer data from your PC to your phone.
Thank you.
If you want to import your contacts from new pc studio instantly, you must have software which supports your phone in PC. You can install the driver software and then you have to connect your phone via cable. After that, with the help of installed software you can manage your phonebook which is in your phone. You have to export or upload the phonebook to your PC.
By this new pc studio you can easily handle all your applications in your mobile although you can save all your data’s and documents in PC. You can import your contact details or phonebook with the help of Ms. Outlook by synchronizing your phonebook.
If you don’t have the software you can download it from this site:
I think you will be very clear now.
Thank you.
Hello Fidelgiancarlo,
You can import all the contacts from your pc to your mobile phone. All you have to do is to Install the Software incase of Nokia it is Nokia PC Suite. Now open the PC Suite. Plug the mobile phone into your computer's USB port Using Data cable that comes with your phone. PC suite supports the Web or outlook .pst files just under the synchronize settings.
If you have some of your contacts stored on your computer and you want to transfer them to your Smartphone, this would be easy by installing your phone’s PC software. Now, different mobile phones have their own PC software that’s why you cannot use one PC suite on all devices because only one will be recognized.
If you have a Nokia phone, you need to install the Nokia PC Suite. Download Nokia PC Suite and install. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Once installed, connect your phone to your computer using the USB cable that came with it then start Nokia PC Suite and then just transfer your files.
For Samsung phones, you need Samsung Kies and there are two versions: the standard Samsung Kies and Samsung Smart Switch. Go to the Samsung Kies download page and download the version designed for your phone. If your phone is running on Android 4.3 Jelly Bean or higher, download Samsung Smart Switch otherwise just download the native Samsung Kies.
Samsung Kies supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. It requires 2 GHz Intel Core 2 Duo or faster processor, 1 GB RAM, 500 MB free space, 1024 x 768 minimum screen resolution, and Microsoft .NET Framework 3.5 Service Pack 1. For media playback, it requires Windows Media Player 10 or higher and Microsoft DirectX 9.0c.
For Samsung Smart Switch, it supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x. It requires 3 GHz Intel Core i5 or faster processor, 512 MB RAM, 200 MB free space, and 1024 x 768 minimum screen resolution. For Windows XP, Windows Media Player 11 or higher is required for media playback.
For OS X, it supports OS X 10.5 Leopard, 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, 10.14 Mojave, and 10.15 Catalina. It requires 1.8 GHz Intel or faster processor, 512 MB RAM, and 100 MB free space.
Once Samsung Kies is installed, connect your Samsung phone to your computer using the USB cable that came with it then start Samsung Kies. Now, just copy your files between devices. For BlackBerry Smartphones, you need the BlackBerry Desktop Software and there are two versions: the standard BlackBerry Desktop Software and BlackBerry Link.
If your BlackBerry Smartphone runs on BlackBerry 7.1 OS or earlier, you need to download the BlackBerry Desktop Software. It supports Windows XP, Windows Vista, and Windows 7. Windows 8.x and Windows 10 are not supported but you can try. For Mac users, you can download the BlackBerry Desktop Software for Mac.
If your BlackBerry Smartphone runs on BlackBerry 10 OS, you need to download the BlackBerry Link. It supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x. Windows 10 is not supported but you can try. It requires Microsoft .NET Framework 3.5 Service Pack 1 so make sure to install it first before installing BlackBerry Link.
Notifications
