How do I increase Frame size in Total Video Converter?
I need to increase frame size from the default setting that is176x144 in “Total video converter”. I cannot find the setting in the drop down list. My target is 320×240 pixels of 3GP output. I don’t really know what to go about this. Would you please be in a position to assist?
I will appreciate.
Best Answer by Aristono Martin
Answered By 20 points N/A #115655
1. First, open your Total Video Converter and then import the file you want to convert. (New Task >> Import file)
2. Go to the Setting option and select the video resize tab. Select your desired video frame size and then click the ok button. (Setting >> video resize >> select your desired video frame size >> ok).
3. Finally, you have to click the button “convert now”. That will now convert your file in your selected option.
Best of luck.
Answered By 0 points N/A #115657
1. First open your total video converter then import your file which you want to convert. (New Task>>Import file).
2. Go to the setting option and select the video resize tab, then select your suitable video frame size, after that click ok button. (Setting >>video resize>> select your suitable video frame size>>ok).
3. Now finally you have to click the button “convert now”.
That’s way you can convert your file in your selected option.
Best of luck.
Answered By 590495 points N/A #314363
Sometimes the allowed maximum screen size for a video profile depends on the application. If you are using Total Video Converter and you don’t see the option to change the screen size to a higher value other than 176 x 144 for the 3GP profile, try using a different video converter. Try using Format Factory.
The latest version at the moment supports Windows Vista, Windows 7, Windows 8.x, and Windows 10. Support for Microsoft Windows XP has been dropped. The last version to support Windows XP is Format Factory 4.3.0. My ESET Smart Security forbids me from downloading from the official website because the file is stored on a website identified with potentially dangerous contents.
If your antivirus or internet security application also forbids you from downloading from the official website, you can download from MajorGeeks: Format Factory. Format Factory allows you to change the screen size for the 3GP profile higher than 320 x 240 pixels.
