How do I insert JPEG flash slideshow for website?
Hello there.  I would like to make an eCommerce website that has a JPEG slideshow.  Can someone teach me how to insert a JPEG Flash slideshow for website?  I have Adobe Flash 11.  Thanks in advance for the help.
Best Answer by Harrington Curtsinger
Answered By 5 points N/A #145040
Hi! Regarding to your problem, there are many ways you can.
This is the very simple way you can do without any application using and installing to your computer, you just insert this to your source code:
<Marquee behavior="left"><img src="your image/s"></marquee>
Note: you can change the behavior with left or right depends on your wants and you can also insert images as long as you want.
Answered By 0 points N/A #145039
Hi Donnaa. I've never heard of inserting JPEG slideshow using adobe flash 11 although I advise you to use adobe dream weaver. There are different ways to insert the JPEG picture slideshow depending on what website you have. I can give you an idea how to insert pictures slideshow using adobe dreamweaver. 1. Open adobe dreamweaver then choose PHP. 2. Then go to insert, media, then choose Image Viewer. 3. Choose the picture you want to display in your slide show. 4. Then click Save As. Don't forget to save it as a .PHP format. I hope this helps. Good luck.
