elsietbrown
20 points
Posted on - 05/13/2013
I have the ISO 2 Din size Erisin ES966D HD 3D DVD player with GPS, SD Card slot and runs on Windows CE 6.0. How do I put ECW plugin Windows CE GPS navigator? Any help would be highly appreciated.
Thanks in advance.
How do I install ECW Plugin Windows CE?
Hello Elsietbrown
Unfortunately, your DVD player system does not have an upgrade option; at least not yet. Windows no longer offers support for this version of software. If you heard of such upgrades, it is probably a myth. This is not unusual for those kinds of players; though I think the Windows plugin your DVD player has works okay under normal conditions. I would suggest you try out a new version of Erisin DVD players.
Expert
