How do I install Handcent new emoji 2 plug-in?
I have the 64 GB Samsung Galaxy S3 I9300 that has the Exynos 4412 Quad chipset, Quad-core 1.4 GHz Cortex-A9 CPU and Android 4.1.2 Jelly Bean.  How do I install the Handcent new Emoji 2 plug-in for funny icons and smileys.  Any feedback?
Answered By 90 points N/A #182618
Hi there Buford J Meadows
You can send cool, fun to the android mobile by using Handcent + emoji Plugin.
How to install –
1st Go to Google play and type Hand cent Emoji Plugin in search
2nd From Search Results select HandCent Emoji Plugin (shown below)
3rd accept, download and install
4th Send “emoji” using SMS
Note – if you’re sending to an android phone, make sure the other recipient also has installed it.
For iPhone it will directly show, No need software
Hope this is helpful for you
Taylor B Campos
