alisd87
Posted on - 11/27/2012
I've got HTC Magic mobile phone. I want to install some Android applications through a USB.
I know that if I download the app from the Google Play store, I can install directly from my phone.
But I want to install an application from my computer to my mobile phone.
What are the procedures for doing it?
How do I install my android app on my HTC Magic?
Dear alisd,
Below is the answer to your query.
Option #1: Connect your Magic to your development machine. From the command line, run adb install path/to/your.apk (substituting in an appropriate path to your APK file). If the SDKtools/ directory is in your PATH, you can run that command from anywhere, otherwise you will need to run it from tools/.
Option #2: Download a file manager program from the Android Market onto your Magic, and use that to install the APK file as found on your SD card.
Hi there user:
Here’s the procedure to install.
First, you’ll need new ROM sd-card. Â
Set your PC in recovery mode. Use recovery image SPF 2.8 ROM.
And, then scroll down the boot menu to Wipe Data/Factory Reset and hit on to erase the previous stored data and cache, just to make sure that the previous user preferences will not do trouble to the configuration of the applications in the new ROM.
And so, after the Wipe is completed, scroll to Apply sdcard:update.zip and click. It will install.
Lastly, restart the phone.
Finish!
Have a great time, thank you for asking.
