How do I install PDF repair full version on my PC?
Hi Guys!
I keep most of my files in portable document format as read only files. There are times when the files get corrupted resulting into the loss of some important information. I have been advised to use PDF Repair full version whenever I have issues with the PDF files. The problem is that after installing this application, it keeps telling me that it has not installed properly. When I restart the computer, I get a message saying an error has been found when the computer was trying to start the application. What can I do?
Best Answer by Stark P Blake
Answered By 40 points N/A #154938
Hi dear Gregory Manilov,
Sometimes the software do not work properly. But you have to carefully before download any software because every software requires specific requirements. To solve your problem I think you can download the following one rather than yours one.
Just uninstall from Control panel and download the software from the site stated
Answered By 0 points N/A #154939
Hello Gregory,
Every software requires some specific requirements to install and run properly. If you properly install the software but got that message than I think there are some problem in the installed software. In this case first of all uninstall the software and install the software again either from a fresh copy of CD/DVD or a virus free drive on your local PC. I prefer to use “Advanced PDF Password Recovery Pro”. This software is reliable and can repair almost every seriously damaged PDF file.
