Is Realbasic 2008 Release 4 available for mac? I've heard about the Control Locking and Tab Stops feature that are now in Realbasic 2008 R4. If it's already available in mac, how do I install it and what are its requirements? Thanks!
How do I install Realbasic 2008 R4 in Mac
You heard right, they have included six new features in it. The control locking which you asked is great. It's letting you lock the IDE control to not edit the size or position and also the Tab stop feature gives you skipping from the specify controls through user interface when you are tabbing. Several warnings are added. There is no need of requirements for the software. It's also available for Mac and you can download it and a simple way to install it. Here is the URL to download.
http://download.cnet.com/archive/3000-2352_4-563541.html
