How do i install a scanner to my computer?
I just want to know how do i install a new scanner to my computer to my pc where i am in real need of scanning some important documents.So can you please tell how to install?
Yes. You need to install a scanner. Then follow the following instructions:
1. Connect the AC adapter to the scanner.
2. Insert the installation disc that came with your scanner into your optical disc drive.
3. You will be getting an autorun option and let it do that for you. You will be getting a new installation wizard. Enter the details accordingly. You will be getting a license agreement which you need to accept.
4. Download a driver or the driver will be in your disc itself. Install it and you will be ready to go.
5. Insert the scanner into a port that is free and that's it.
Cheers.
Find the cable in the modem from your ISP, most modems have and ISP for a monthly fee. Turn off your PC and connect it into the Ethernet cable in your modem Ethernet port into the network card.
Plug the modems power supply and connect  into the router available in the Ethernet port. Turn on the modem and install the driver into the computer follow the onscreen instructions. Once done, restart your computer and test the modem ensuring all lights are of the  modem  is blinking, double check also the browser icon and launch the web browser
Hi Rizwanmohammed
    If you are using a window 7 it is expected that when you install a new device to your computer, it is automatically detected but you can still check it if it is really install successfully or not. to check just do the following:
1. Go to the Start Button
2. In the left side of the monitor, click Devices and printers
3. You can see different devices that has been installed by your computer system, then if you find the scanner, makes sure that it has a check mark, to know that the scanner was successfully installed but if there were no image of your scanner, please do the following:
a. connect your scanner
b. wait for the installation of your scanner device
c. after detecting your new device, Â just follow the instruction
d. then click finish.
