Hi! I would like to know how to install sonar x1 in my pc. I have been trying to install the application but every time I don't get the application at the start menu programs.When I check my c folder, I get the program folder with some files in it that I do not understand. I had that similar problem with some printer installation which I have not been able to solve.
How do I to install sonax x1 in my pc!
Hi Dear Thomaas,
Dear i think your computer has viruses. Some viruses are much critical and make many problems in computer.
The virus makes some unusual files with un understandable names. These files are much big in size and un delete able.
So that you are facing this problem. Dear you should repair your windows for these viruses.
Get a good antivirus and scan your computer.
The other method is this, please try to change the installation target location. And see that it gives the same results.
Or now it is working.
Sometimes virus makes much problem.
I hope you got your answer.
Thanks
