How do I install Windows 7 64 bit Home Basic without an installation CD
Asked By 340 points N/A Posted on -
Hi! I want to re-install Windows 7 64 bit Home Basic on my PC due to some issues I’ve been encountering lately. However, I lost my installation CD. Is there a secure way to proceed with the installation without a CD? Thank you for any help.
Best Answer by
Answered By 0 points N/A #330074
Hey! Well, you can definitely re-install the Windows 7 64 bit Home Basic without an installation CD. There are primarily two methods to carry this task out. Both of them require your product key (if the older one does not work, you will have to reach out to the Microsoft office centre and obtain a new key).
The first way is to install the OS via a bootable USB. Or you can download the ISO file of the version you own and install the program with the ISO image file. Any other methods are probably illegal or run the risk of cracks or piracy. This will prove to be harmful to your device.
