My iPad is running out of space. If I try to download an app, I get an 'out of storage space' error and it can be very frustrating. I have a 32GB. How do I find out what is using most of the space in my iPad? How do I clean out my camera roll?
How do I know which app uses the most storage on iPad?
Hello Debrazjbate, Most of the bulk of heavy storage eaters are video files. From your settings, go to the General then select Usage and tap Storage. This is where you can see the exact space each application, files, or music occupied by them. If you are into video or movie downloading, try iCloud storage. If you’re using iOs 8, check your Settings then tap iCloud, tap Storage and then select Storage. After videos or movies, music files occupies a lot of space, so check which files you want to keep and delete unnecessary volumes of files.
