How do I know that in Zero Popup trojan was already detected? I want to use this as a popup killer. Could it detect a certain popup as a serious threat to the system and keeps log of the detection? Thanks!
Hi Judith,
Zero pop-up is a small effective tool to prevent your PC from unnecessary pop-ups or say Trojans without any manual direction.
1. It kills certain advertisements, banners and threats coming from internet and even Google Ads if they are malicious.
2. It is very light in terms of size and takes a little of your system size.
3. Zero pop-up contains a log of Trojans removed like any other anti-virus software.
4. A new option of F9 will list an internet website to white list and adds another great feature.
Hello JudithLBarton,
Zero Popup is indeed a lightweight utility that blocks popup windows for you. To inform you that it has detected and blocked a popup, the utility can be configured to play a sound for you, blink its icon and finally make a beep sound.
Unfortunately, there is no way to tell if it blocked a serious threat and log it for you.
