How do I make blends using Photoshop images?
I am looking for a way to create blends of different images and brushes for a wavy background. I am able to use the brushes and to crop the Photoshop images but making them blend in posing a bit of a challenge. Further, I would like the photos to assume the color of the background. What this means is that if the background is blue then the photo should appear to be bluish to have it blend in well. Thanks.
Best Answer by Lorraine P Goodman
Answered By 30 points N/A #158010
Hi
Good day!! Photoshop blends the image with the colors around it by default, so … Photoshop to do what you want it to in one simple action blend seamlessly on the css bgcolor. For color profiles in Photoshop, go to "View" -> "Proof Setup" I normally choose "Windows RGB" Also make sure you're working in RGB mode. "Image" -> "Mode" -> "RGB Colors." … Is there any reason why you're saving it as a jpg instead of an alpha png? How were you saving it as a JPG? Did you do "Save AS" or "Save for Web & Devices?" I recommend using alpha png instead
Thanks
Answered By 0 points N/A #158011
Having read your question, what I would suggest is not using the blend modes. I think you need to tweak the hue/saturation for each image on your project. You could increase or decrease each color channel per image using the hue and saturation editing mode under (menu) image > adjustments>hue saturation on Photoshop.
Also, a bit of tutorial might help through this blog's blending modes page.
