How do I make dynamic report title access 2010?
I want to make a dynamic report title access 2010 and have them updated automatically. If I want to make changes, will they update automatically? How do I make dynamic report title access 2010 and have them update automatically?
Best Answer by Bedard Karen
Answered By 0 points N/A #152821
This solution may be simple. To do this you need to link the Chart Title to a formula. An example formula for you
=”Your Title Name”&D1
 I think it will be helpful for you. If you want to learn more about this just follow this tutorial  http://www.thecompanyrocks.com/create-dynamic-chart-titles-in-excel/
Answered By 0 points N/A #152822
Hi, you can have a free tutorial on making a dynamic report in Microsoft Access at tutcity.com/access. For a detailed and step by step process, you can go to ehow.com. In the search box, type “How to Create a Dynamic Report in Ms Access”.  Yes, you can update them automatically. On how to do it, visit https://access-programmers.co.uk/forums/showthread.php?t=137153
Answered By 0 points N/A #152823
Hello Emily!
Well, I will show you how to make a simple report based on a single query. In the "Create Tab", click the Report command and then your report should instantly appear. Maybe you want change look of that report so you can do that in "Layout View". I will give you example: I want that he shows only orders from December, so I'll right click the Pickup Date column>Date Filters>All Dates In Period>select December. And yes, they will update automatically once you save them.
Thanks!
