Hi guys. I'm having trouble with my Flash Player. Every time I encounter a website with Flash content, the video seems to lag and a bit choppy. Is this a video card problem? How do I make Flash Player run faster? I have a 512 MB Geforce Video Card.
If the flash player is not running faster, you need to check minimum system requirement and the version of flash player.Â
This can be problem of video card, because some cards are compatible with motherboard.Â
You can check the compatibility and if you want you can expand the RAM which will give you extra speed.
You can verify the installed version of flash player and troubleshoot in short time to make it better.Â
Refer to the link for troubleshooting.
