how to make MSN home page MSN is a fun site as I want it as my homepage its contain hardly info which is customize preference & needs there are also some frequently links and news we get every day you would expose or fresh web content as a regular basis with MSN as your homepage. How do I set this as homepage?
Yes, you can make MSN your home page as you can make any website as your home page. But it need to be configured to stay at the home page.Please follow the whole procedure step by step.
Open internet and open MSN site
Click tools
Choose inter option
Locate general page finds homepage option
Highlight the current home page with your mouse and drag mouse
Tick delete key on your keyboard to get rid of the current page
Type new home page by using the keyboard
Tick ok & save new home page
Click home now sees MSN will be your home page. And your problem will be solved.
To set MSN as your home page on Google chrome, simply open the chrome browser, on the far right corner click menu>settings>select appearance>selct change home page>enter www.msn.com Click on the home page icon a the top right of your chrome browse to confirm is your homepage has changed to MSN.
MSN is the default home page for the Microsoft Internet Explorer web browser. If you are using a different web browser, it will also have a different default home page. If you want to use MSN as your default home page, it shouldn’t be a problem and can be done in any browser you are using. In Google Chrome, there is no home page shown.
It just displays a new tab on startup with the Google logo, search bar, and a couple of thumbnails. To set a new home page for Google Chrome, in Google Chrome, click the “Menu” button on the upper right corner of the screen to display the dropdown menu then select “Settings.” Another way is to type without quotes “chrome://settings” in the address bar and hit Enter.
In the “Settings” tab, under “On startup” section, select “Open a specific page or set of pages” then click “Set pages.”
Google Chrome click Set pages
In the dialog, type without quotes “https://www.msn.com/”, click “OK” and that’s it.
Google Chrome enter home page address
You now have MSN as your default home page in Google Chrome.
1....
