How do I make my hidden folders visible?
I am using a Windows 7 computer. I turned some of my folders into invisible or hide mode.
One time,I wanted to view the contents of that folder but I don’t know what to do to make it appear.
I really need your help on what to do to make the hidden folders visible again can someone teach me please?
Best Answer by ashf214
Answered By 0 points N/A #160204
Click on Start > All Programs > Accessories > Windows Explorer. Windows Explorer will open on your screen. Click on the "Tools" drop down menu option. Click on "Folder Options…" and the Folder Options window will open. Look under the "Advanced settings" menu for the "Hidden files and folders" section. Click the radio button in front the "Show hidden files, folders, and drives" option. Click "Apply" and "OK". With the exception of protected operating system files, all hidden files, folders, and drives are visible.
Answered By 0 points N/A #160205
I can help you to make the hidden files on your computer visible. I suggest you to follow these steps:
>>Go to Control Panel.
>>Click on Folder Options.
>>Click on the View Tab option.
>>Click on Show hidden files, folders and drives.
>>Click on Apply button.
That’s all. You can now see the hidden files and folders on your computer. To hide it again, right click and select Properties, then check the Hidden option and click on OK button.
Thanks and regards,
Skarbos Jay.
