How do I make office building Photoshop shape in 3D
Hi.  I just created an office building Photoshop shape in 2D.  How do I make it in 3D to have a better perspective?  I use Adobe Photoshop CS6 and Windows Vista 64 bit.  Any help would be much appreciated.  Thank you.
Best Answer by Johnson Eckhoff
Answered By 0 points N/A #136277
Edward,
Adobe photoshope CS6 doesn't have that option.Best Install Adobe Photoshop CS6 extended application only photoshop extended have 3D tools,with it you can manipulate 3D objects.
if you already have Installed Adobe Photoshop CS6 extended you will see an option for 3D. With the pull down menu,select 3D extrusion option then just click the "create" button to extrude the selected 2D object into 3D objects.
Answered By 0 points N/A #136278
I am not sure that make office building Photoshop shape in 3D. But you create 3D objects using adobe Photoshop. Create and adjust 3D extrusions following manual
<> Select a path, shape layer, type layer, image layer, or specific pixel areas.
<> Choose 3D > New 3D Extrusion From Selected Path, Layer, or Current Selection.
<> With the mesh selected in the 3D panel, select the Deform or Cap icons at the top of the properties panel.
<> Edit numerical settings in the Properties panel, or drag the interactive extrusion controls in the document window.
If you need more help watching the video tutorials.
https://www.youtube.com/user/dramenon/videos
http://www.dailymotion.com/video/x3qb5s
Best regards
