Hi guys. I need your help. I just received about a dozen PDF's. How do I make PDF to editable PDF? I don't want to type and edit the whole thing in Word to save precious time. Do I need a program for this? I have Adobe Acrobat XI if that matters. Thanks.
Hi Dorothy Davis
It seems you want your PDF files in Word that's why you don't want to waste your precious time rewrite it. Its simple using PDF2Word Converter this application lets you convert PDF files into Ms Word and RTF formats in just a few steps. This incredible application enables you to export the text, BMP images and other contents from PDF document into a Word document, preserving the original page layout.
Hi Dorothy,
You can try to make your PDFs Editable with Google Docs,in this way you can convert the file to Word or Text format. And good thing about this is you can also have scanned PDFs editable. Here’s how:
Sign up a Google account.
Click on Docs icon.
Then when you are in Google Docs, click on Upload. Select the file to be uploaded then click Convert text from PDF or Image files to Google Docs. Then click Start upload.
Then you can now edit out your PDF documents.
OR
You can go straight by opening the PDF on Microsoft Word. Just open the PDF file like how you would do in a document. The formatting may not be the same regarding the spaces.
