Hi there. How do I create a virtual multi folder directory in IIS? I use Microsoft Internet Information Services Version 5.1 on Microsoft Windows Server 2008. Can someone teach me step by step? Any help would be much appreciated. Thanks in advance.
How do I make a virtual multi folder directory?
Hi Dorothy,
the IIS compatible with Windows Server 2007 is IIS 7.0 you need to upgrade your version
Then you should open IIS Manager
Start menu -> All programs -> Accessories -> Run
Type "inetmgr" -> ok
Expand the computer or the site you want to add in the virtual directory
click right on the site at the folder where you want to create the virtual directory -> new -> Virtual directory
in the wizard -> next
type the name of the new virtual directory you want to create -> next.
in the path box, browse the directory ( physical one) where the virtual directory is created then "next"
Select the permissions you want to give to users
Click "Next"-> " Finish"
