How do I manually add NOD32 server registration?
Hi.  I'm having problems with my ESET NOD32 Business Edition antivirus.  It keeps on cutting my Microsoft Windows Server connection.  How do I manually add NOD32 server registration for my Windows Server?  My system runs on Windows 7 64 bit.  Any help would be much appreciated.  Thanks in advance.
Best Answer by Marshall Kwak
Answered By 15 points N/A #145059
Hi Donnaa Gordon,
I just want to inform ESET already released a security software specific to run on servers. It
is called "ESET File Security for Microsoft Windows Server".
You can contact your ESET security software distributor for a migration.
To answer your question, here are the settings that you can adjust from your antivirus to work
with your server. These settings will work with your server processes and avoid potential conflicts with other applications without sacrificing the protection of your server.
Here is the step by step instructions on how to configure your security software complete with
illustration.
Answered By 0 points N/A #145060
Hi
To manually add NOD32 server registration for my Windows Server connect to the internet and such for a free serial key .enter it.you can also get an update of the antivirus then download Eset Nod32 Antivirus v4/v5 and download Eset Smart Security v4/v5 in your computer and get the eset nod32 serial keys from here and set up nod32 username and password , and click on the update button and you are done.
Serial key are available for free downloadfull89.blogspot.com/2013/04/eset-nod32-serial-keys-2013-nod32.this will work very well.
