How do I map a network drive?
Mapping a drive means sharing your drive to the network. Drives A & B are assigned to floppy disks and can never be shared. That is, if the server does have floppy drives A & B. But usually, servers in a Local Area Network remove their floppy drives because nowadays, floppy disks are becoming obsolete and will soon be replaced by USB flash drives.
If your LAN server doesn’t have floppy disk drives, you can therefore map letters A and B. Here’s how, using just your Windows Explorer.
You will not see the letters A and B in the available drives if those letters belong to the floppy disk drives of the server. Always remember, floppy drives can never be shared.
