How do I Maximize My Android Phone
Hi Alisonnlopez,don’t worry. If you having problem with Android Phone’s battery and you want to maximize the battery life then follow the steps:
This is a very good link to maximize your android phone: https://www.howtogeek.com/howto/25319/complete-guide-to-maximizing-your-android-phones-battery-life/ It depends on the usage of its tools in a day; with battery life can be improved upon turning on and off it's feature sets. This website show how to turn off set of tools like notifications and bunch of other items. Also, android phone battery life can be improved upon resetting the phone. It is very important to backup your android phone before maximizing it. To prevent any loss of data. Here is the website showing how to backup your android phone. This is a tutorial video on you tube to perform the backup.
Good day to you Alisonnlopez!
Thanks for asking that question. I agree with Brian Tinny on some of his tips on how to maximize the battery life of your android phone.
You must follow each tips step by step to improve the battery life of your android phone. But the life of your battery depends only on the usage of your phone on how long you use it on playing games, browsing the internet using WiFi, downloading applications, etc.
One tip I can share for you is when you charge your phone you must turn it off and wait until the battery is full before using it. This will help the life of your battery to maximize.Â
