I have multiple large images in png file format that I would like to merge into one single png file without re-encoding. Png images are 9000×9000 pixels in size. How do I merge very large images into one. Do I need an image library for this? Thanks.
How do I merge very large images into one image?
Hi Brant,
You don’t need to think about image library or anything else. Just take it simply. Image library and other options are very time consuming I think. Just convert the PNG to PDF and try to combine them into one file. You can use a free batch converter for the job.
https://www.macupdate.com/desktop
Just download the free trial version.
Good Luck.
Use the following codes below :
