How Do I Monitor Bandwidth Usage On My Network
Hi. What are the steps to be followed as to how do I monitor bandwidth usage on my network? I am totally new to this concept. Please reply ASAP. Thanks in advance.Â
Hi. The steps to be followed as to how do I monitor bandwidth usage on my network are as given below-
1) Download the app Networx on your PC.
2) Then double-click on it to begin the installation.
3) Select a language before proceeding
4) Then select the network connection which is to be monitored
5) The setup is now complete
6) The monthly, daily or weekly transfer rate is shown by clicking on settings, then main and then tray icon
7) To select the networks to be monitored, click on settings, then go to main and click on networks. Then click on only networks selected below option
8) To see the data usage per person, you can click on settings, advanced and then synchronize usage data option
9) To generate the report, right-click on the Networx app, and click on usage statistics and then select the monthly report optionÂ
10) Close the window
Hope we helped.
