Hi. My internet WiFi connection seems to be intermittent as I am having frequent dropped signals. I have the Linksys WRT310N UltraRangePlus Wireless-N Gigabit Router with 300 Mbps wireless data transfer rate. How do I optimize wireless connection Windows 7?
In order to optimize your WiFi connection, you should before everything determine what the problem is and where did it come from.
There are some problems related to your hardware and some others related to the software.
If you cannot determine where the problem is coming from, I recommend that you install some software like "tune up utilities" for example, and then you can check the problem and then optimize your WiFi connection easily in no time.
