How do I permanently turn off hp info center?
HP info center always pop up when I turn on my computer.
How would I permanently  turn off HP info center?
To lessen program running during start up.
Thanks
Thanks
Hi,Â
Insert HP CD into your Rom and go to Start menu and then run.Â
Type msconfig and press enter. It will open configuration utility. There just click on startup tab and look for the HP programs. The check box will appears next to the programs just simply remove the check from the program box which you don't want to use and press ok.
Restart your system when you get in windows again go to startup and then run type services.msc. here look for HP programs and disable them by double clicking on them.
Hope the answer for your question
Two options:
1. Get the HP CD that you got with your computer/printer. Put it in the disk when it asks for the CD installer. It is going to install The HP application which its looking for at every startup.
Hope you can find that HP CD.
2. Can try this
