How do I prevent my web cam from hanging?
I have experienced problems with my web cam such as it shutting down after 5 seconds of opening and hanging while taking a video. What do I do so that this no longer happens?
          Camera is easy to install and if there are some problem about it you can try it, Try to install it to other computer. See if it will run ok. If it run ok, there is something wrong with your computer, there might be come components or drivers that do not install properly to your computer. Try to uninstall the camera and install it again. See if it works. If not, this is the time that you need to consult to the shop where you bought your camera. They can help you a lot about that. There might be defect or something wrong that need to replace with a new one, you can use also the warranty of you camera to avoid buying new one. Good luck.
If you are using a laptop and this happens with your web cam, make sure you have the latest driver installed. Visit your laptop manufacturer’s website and download the latest driver for your webcam. If your laptop comes with a driver CD, check its contents and look for a suitable driver for your webcam. The driver CD normally comes with different versions of the driver.
If the CD contains different versions of the driver for the webcam, try installing each of them and see which one works better. If you are using a Dell laptop, go to Dell Drivers and Downloads. Enter your laptop’s service tag code or model number to see the available downloads. If you are using an Acer laptop, go to Acer Drivers and Manuals.
Enter your laptop’s serial number or model number to see the available downloads. If you have an HP laptop, go to HP Customer Support and enter the model number of your laptop. Before downloading, make sure you’ve selected the correct operating system.
